Closed Thread
Old 10-14-2006   #1
HizbullaH
HizbullaH's Avatar
Last Online: 09-06-2011
Default Learn How To Attack A Simple WebSite :D
To Attack A Simple WebSite Or A Simple Or Normal Protected WebSite ( Not Powerful Protected WebSite ) , Dos Attack Might Be Useful In This Case ...
For Dos Attacking All What You Need Is This Program ~~>
[link removed]
This Program Attacks On The Ip Of The WebSite.
To Know What Is The Ip Of The WebSite Click Start Then Goto Run And Type ~~> Cmd , Click Enter Then Type ~~> tracert www.example.com , Then Press Enter And You Will Get The Ip
Now Open The Program And Put The Ip In The Program ( Keep The Interval 50 )
And Click Dos Attacking...
Note : Damaging The WebSite Depends On Your Connection Speed ( Especially Upload Speed ) , If Your Connection Is Slow It Will SlowDown The WebSite And The Effect Will Take A Long Time To Be Seen , But If You Have A Real Fast Connection The DataBase Of The WebSite Will Be Corrupted Enjoy
HizbullaH is offline
Old 10-14-2006   #2
IM@D
IM@D's Avatar
Last Online: 05-28-2013
Groans: 23
Groaned at 22 Times in 18 Posts
Default Re: Learn How To Attack A Simple WebSite :D
You rock Hizbullah
But do you know what kind of attack is it?
what will happen to the website
IM@D is offline
Old 10-14-2006   #3
HizbullaH
HizbullaH's Avatar
Yes Bro Of Course .. It Is A Dos Attack ..
If You Have A Slow Or Normal Connection It Will Slow Down The WebSite , And It Will Take SomeTime ....
But If You Attack It From A Real Speed Connection It Will Corrupt The Database Of The WebSite ....
Using ( BotNet ) Is Better , The BotNet Kills The WebSite , But It Is Somehow Complicated And Needs MIRC And And .... So Start From Zero
Old 10-14-2006   #4
god
god's Avatar
Last Online: 02-14-2010
DDos is so skiddy, and skiddies will burn, no comment...... i just dont like dDos attacks
--Capitalisation is the only difference between "I helped my uncle Jack off a horse" and "I helped my uncle jack off a horse" !!
http://img482.imageshack.us/img482/4889/hell7ta.jpg
god is offline
Old 10-14-2006   #5
HizbullaH
HizbullaH's Avatar
Bro The Pplz Who Don't Know Must Start From Zero
Old 10-14-2006   #6
god
god's Avatar
thats not a start where's the learning in opening a program, inputting a link, and clicking "go" or whatever, mmm if you wrote an article about how dDos worked, they would be able to write a simple batch file to do the job :P
thats just my opinion anyway
god is offline
Old 10-14-2006   #7
HizbullaH
HizbullaH's Avatar
I Was Banned In This WebSite ~~> http://www.nsaim-lil.com/ <~~ Loock What Happened To It ...
Old 10-14-2006   #8
KeXasthur
KeXasthur's Avatar
Last Online: 12-17-2012
so Now i can attack the [edit: no evil links mmkay ]
Yummmmm !
KeXasthur is offline
Old 10-14-2006   #9
god
god's Avatar
DONT USE THIS cause you can and WILL be easily traced... thread closed and direct link removed....if you're smart enough to figure out how to use a proxy and ddos, you should know how to google for a program..
god is offline
Closed Thread
attack, learn, simple, website
tayyar.org under attack ballack Computers & Information Technologies 2 02-14-2007 04:34 PM
a simple question ABOUT Lbc SysTaMatIcS Political Forum 3 01-24-2007 04:09 PM
General Under Attack MayaFPM Political Forum 9 11-23-2006 12:51 PM
Solida Under attack! Malak Political Forum 6 10-06-2006 11:43 AM
Simple Note .. FreaK Vcoderz Lobby 18 09-07-2006 09:58 PM
