Old 10-18-2010   #11
Mared_3400
Mared_3400's Avatar
Default Router and modem?
Is the router and modem in the same device?
If so contact Ogero and they will give you all the information you need.
It happened to me before.
وطني دائما على حق
Mared_3400 is offline   Reply With Quote
Old 10-20-2010   #12
Google
Google's Avatar
Last Online: 05-30-2013
Enter the command prompt (cmd.exe) and type the following:
route PRINT
It will output the interface list, the IPv4 route table and the IPv6 route table.
Take a look at the IPv4 route table. It looks something similar to this:
IPv4 Route Table
Active Routes:
Network Destination Netmask Gateway Interface Metric
0.0.0.0 0.0.0.0 192.168.1.1 192.168.1.101 40
127.0.0.0 255.0.0.0 On-link 127.0.0.1 306
127.0.0.1 255.255.255.255 On-link 127.0.0.1 306
127.255.255.255 255.255.255.255 On-link 127.0.0.1 306
192.168.1.0 255.255.255.0 On-link 192.168.1.101 296
192.168.1.101 255.255.255.255 On-link 192.168.1.101 296
192.168.1.255 255.255.255.255 On-link 192.168.1.101 296
224.0.0.0 240.0.0.0 On-link 127.0.0.1 306
224.0.0.0 240.0.0.0 On-link 192.168.1.101 296
255.255.255.255 255.255.255.255 On-link 127.0.0.1 306
255.255.255.255 255.255.255.255 On-link 192.168.1.101 296
As you can see, the gateway is 192.168.1.1; This is the router IP address.
Google is offline   Reply With Quote
changing, dlink, key, router, security
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
