Computers & Information Technologies Everything related to computers and internet.
Old 11-16-2010   #11
Last Online: 06-12-2019
This should work:
Code:
#include <iostream>
#include <string>
using namespace std;
int main() {
    char a[100];
    char b[100];
    int la, lb;
    bool isSubstring = false;
    cout << "Enter first line: ";
    cin.get(a, 100, '\n');
    cout << "Enter second line: ";
    cin.ignore();
    cin.get(b, 100, '\n');
    la = strlen(a);
    lb = strlen(b);
    for(int i = 0; i < lb-la+1; i++){
        for(int j = 0; j < la; j++){
            if(b[i+j] != a[j])
                break;
            if(j == la-1)
                isSubstring = true;
        if(isSubstring)
            break;
    if(isSubstring)
        cout << "Yeah Baby!" << endl;
    else
        cout << "No! No! No!" << endl;
    return 0;
The Following 2 Users Say Thank You to Tawa For This Useful Post:
nabilsaleh1992 (11-20-2010), ZC (11-16-2010)
Old 11-16-2010   #12
ZC
ZC's Avatar
Last Online: 07-15-2013
I ran it bi 3a222id:P man thanx aloooooooooot:P i guess ur smarter than me:P i didnt even understand what u did:P
Books all say different things while people flap their yellow wings trying
to soar by being a whore of life!!!!
ZC is offline   Reply With Quote
Old 11-16-2010   #13
ZC
ZC's Avatar
can u explain the algorithM :P?
Old 11-16-2010   #14
ZC
ZC's Avatar
BTW fio problem... awwal string 3tee TAWAKBIR
teneh string 3teee AKBIR bi illak no :P
Old 11-16-2010   #15
ZC
ZC's Avatar
not working toli3
Old 11-16-2010   #16
Originally Posted by ZC View Post
not working toli3
As I read in your post where you explained the homework, the program has to check if the "FIRST" string is a substring for the "SECOND".
So, if you input AKBIR then TAWAKBIR, it'll work.
So I guess it's working.
Old 11-20-2010   #17
nabilsaleh1992
nabilsaleh1992's Avatar
Last Online: 11-20-2010
Default the opposite is true...
ask the user to input a string.. and then input another string.. the program should check if the second is a substring of teh first
it's the opposite you have to check if the first is a substring of the second.
dude im taking the same course and i have the same assignment, would it happen that we're in the same class?
nabilsaleh1992 is offline   Reply With Quote
Old 12-25-2010   #18
Adam
Adam's Avatar
Last Online: 06-03-2013
Groans: 25
Does anyone know if there is any advantage in performance when using recursive binary search rather than normal binary search?
EDIT: I also find this piece of code when reading about recursive binary search...
Code:
int nMid = (nMin + nMax) >> 1;
Does anyone knows what it means?
Old 12-25-2010   #19
Code:
http://www-numi.fnal.gov/offline_sof...rib/shift.html
Adam (12-25-2010)
Old 12-28-2010   #20
Google
Google's Avatar
Last Online: 05-30-2013
Code:
This is just a division by two.
Google is offline   Reply With Quote
The Following User Says Thank You to Google For This Useful Post:
Adam (12-28-2010)
helpc
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
