E-Learning Center E-Learning tutorials and competitions.
Old 01-27-2007   #71
kalach89
kalach89's Avatar
Last Online: 06-21-2007
Default Re: Tips n tricks!
Rename your digital photos automatically in Windows XP
Unless you really have a lot of time on your hands, I doubt you want to go through the massive folder that contains your European vacation photos and rename them Europe_1.jpg, Europe_2.jpg, and so on down the line. If you're running Windows XP on your computer, you don't have to do this. Simply apply this hack to quickly apply a meaningful label to every picture in the folder.
* First, open the folder and select View > Thumbnails.
* Click the last picture in the folder you want to rename, hold down the Shift key, and click the first picture; this will select them all.
* Right-click the first photo, and select Rename from the drop-down menu.
Windows XP will highlight the filename for the first photo, enabling you to give it a descriptive name. After you type in the name, click the white space outside of the photo and watch as Windows applies the name with a sequential number to each picture in the folder.
Enjoy
Kalach89
Old 01-27-2007   #72
kalach89
kalach89's Avatar
IF Display song info not working" in MSN Messenger
Ever had this error where you would play a song in Windows Media Player, but even though the "Show Song Information" checkbox is checked in the options, MSN Messenger still doesn't display the song currenty playing?
Here's how to fix it:
open up Windows Media Player,
click the Tools >
menu, then Options, then Plug-ins tab, look under the Background category and verify that the
MSN Messenger Music Plugin is checked.
Enjoy
Kalach89
Old 01-27-2007   #73
kalach89
kalach89's Avatar
Zip a file into bite-size pieces (something we usually see while downloading movies from rapidshare.de)
Winzip allows splitting of an existing ZIP file into multiple pieces to ensure easier transfer over the internet. Open the file in WinZip (in the Classic Interface), open the Actions menu, click Split, then choose a file name and size for the pieces
Enjoy
Kalach89
Old 01-27-2007   #74
kalach89
kalach89's Avatar
Run Commands
compmgmt.msc - Computer management
devmgmt.msc - Device manager
diskmgmt.msc - Disk management
dfrg.msc - Disk defrag
eventvwr.msc - Event viewer
fsmgmt.msc - Shared folders
gpedit.msc - Group policies
lusrmgr.msc - Local users and groups
perfmon.msc - Performance monitor
rsop.msc - Resultant set of policies
secpol.msc - Local security settings
services.msc - Various Services
msconfig - System Configuration Utility
regedit - Registry Editor
msinfo32 _ System Information
sysedit _ System Edit
win.ini _ windows loading information(also system.ini)
winver _ Shows current version of windows
mailto: _ Opens default email client
command _ Opens command prompt
Enjoy
Kalach89
Old 01-27-2007   #75
Last Online: 02-20-2014
splitting files can also be done using winrar.
Old 01-27-2007   #76
kalach89
kalach89's Avatar
Internet Explorer Shortcuts
CTRL+A - Select all items on the current page
CTRL+D - Add the current page to your Favorites
CTRL+E - Open the Search bar
CTRL+F - Find on this page
CTRL+H - Open the History bar
CTRL+I - Open the Favorites bar
CTRL+N - Open a new window
CTRL+O - Go to a new location
CTRL+P - Print the current page or active frame
CTRL+S - Save the current page
CTRL+W - Close current browser window
CTRL+ENTER - Adds the http://www. (url) .com
SHIFT+CLICK - Open link in new window
BACKSPACE - Go to the previous page
ALT+HOME - Go to your Home page
HOME - Move to the beginning of a document
TAB - Move forward through items on a page
END - Move to the end of a document
ESC - Stop downloading a page
F11 - Toggle full-screen view
F5 - Refresh the current page
F4 - Display list of typed addresses
F6 - Change Address bar and page focus
ALT+RIGHT ARROW - Go to the next page
SHIFT+CTRL+TAB - Move back between frames
SHIFT+F10 - Display a shortcut menu for a link
SHIFT+TAB - Move back through the items on a page
CTRL+TAB - Move forward between frames
CTRL+C - Copy selected items to the clipboard
CTRL+V - Insert contents of the clipboard
ENTER - Activate a selected link
F1 - Display Internet Explorer Help
Enjoy
Kalach89
Old 01-27-2007   #77
ulias
ulias's Avatar
Last Online: 07-16-2012
okey gus try this : press the windows logo key (win key) + the pause/break button it will show the system propreties go to hardware/driver signing/ and select ignore- install the software auto.. this will remove the windows verification on each driver signing detail and will save time wile installing bluetooth aor any other device with lots of com-ports and stuff like that
Chief of Staff
ulias is offline   Reply With Quote
Old 01-27-2007   #78
ulias
ulias's Avatar
double click on ur network places icon on the desktop or where u can find it (not my network yours !! :P ) and select from the left panel : show upnp devices, this will alow your computer to detect all routers and devices connect to the network
Chief of Staff
Old 01-27-2007   #79
ulias
ulias's Avatar
how many of you have downloaded the windows media player 11 or IE7 and cant install it just because ur not a genuine user :P i have found a way 1- toremove the windows genuine check ( a software that does everything ) and 2- to make ur wiondows xp genuine so u can download the softwares u want from microsoft and give the big giant a kick ! long live open source !! (firefox rocks!! )
Chief of Staff
Old 01-28-2007   #80
Sony
Sony's Avatar
Last Online: 07-12-2012
firefox tip: if you wanna firefox open your last windows and tabs, just go tools>>>>options>>>main[start up]..when firefox starts:{the default is: my home page}change it to 'show my windows and tabs from the last time
i use it to open 21 forum
the Hell is empty...all Devils are here...
Sony is offline   Reply With Quote
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
