E-Learning Center E-Learning tutorials and competitions.
Old 05-22-2007   #91
Last Online: 08-01-2019
Default Re: Tips n tricks!
here are 11 tips to hide your identity online (source) :
1. Clam Up. If a site requires registration, fill in only the required fields. Look closely for at any checkboxes relating to sharing your information – depending on how they're worded you'll need to check or uncheck the box to deny sharing permission.
2. Lie. If the registration isn't part of an important ongoing business relationship, consider filling the required fields with… shall we say… truth-challenged data. Or get ready-made registration information from www.bugmenot.com.
3. Look for the Lock. The lock symbol in your browser's Status Bar and "https" in the Address Bar show that you've got a secure connection. Look for it any time you're about to engage in a financial transaction. The lock isn't a guarantee of security, but its absence is a guarantee of NO security.
4. Sniff Out Phish. If you get an e-mail about a problem with your bank or other financial institution, never click any links. Go directly to the bank's web site and research the problem there. If there is no problem, inform the bank about this fraud attempt.
5. Sniff Out Phish, II. Both Internet Explorer 7 and Firefox 2 include built-in detection of fraudulent web sites using a combination of blacklisting and actual web page analysis. Be sure this feature is turned on, and take it seriously.
6. Search Safely. For additional help avoiding dangerous web sites, consider installing one (or more) of the helpful site-safety add-ons described in our Search Securely roundup. If you see a red flag, stay away!
7. Control Yourself. Chances are good your security suite includes a private data protection option. When the data you've chosen to protect is about to go out in a web form, e-mail, or IM, it either prevents transmission or replaces the private data. This feature's not for everyone, but if you feel you need help controlling what you send out, give it a try.
8. Use One-Shot Credit Cards. Check with your credit card company online – they may offer an option to create one-shot credit card numbers. When you exercise this option to make a purchase online, the number received by the merchant will be valid for just that transaction.
9. Educate Your Kids. You can be fanatically careful, but it won't do any good if your kids e-mail or IM personal information to strangers. If they're old enough, get them on your team to protect your family's identity. If not, use parental controls or private data protection to limit their ability to blab family secrets.
10. Secure Your System. Forget the Internet – worry about a colleague or neighbor-kid who sits down at your system and copies off your personal files. Use strong passwords, and be sure to lock the desktop when you step away from the computer.
11. Think Outside the Box. Don't believe everything that comes in an envelope. And shred any sensitive information before discarding or recycling it. Identity theft isn't limited to the online world!
Old 06-16-2007   #92
Google tip, find a specific type of files.
filetype:file extension and search term. It may be obvious, but this lets you search for files with a certain extension, such as PPT for a PowerPoint presentation on your topic.
Old 06-20-2007   #93
Moro
Moro's Avatar
Last Online: 04-10-2011
Default Change your Computer Password
This Topic will teach how can u change your computer password without nowing your old Passward
1. Click "Start" Then Click "Run".
2. In the dialog box type in "CMD" and select "OK". (Opens Command Prompt)
Or you can manually open CMD by navigating to "C:\******\system32\cmd.exe".
3. Once Command Prompt is open, type in "net user" and hit enter.
This will display all user accounts.
4. Now type in the following command: " net user (ACCOUNTNAME) * " and hit enter
Example: net user Myname * [ENTER] (Dont forget to add the asterisk)
5. Now it will ask for a new password, enter a password and hit enter once again,
(PASSWORD WILL NOT BE DISPLAYED SO MAKE SURE THERE ISNT ANY TYPOS)
6. Now it will ask you to confirm the password, Simply type in the password again and hit enter.
7. Now the password id changed! To exit command prompt simply type "EXIT" and hit enter.
Moro is offline   Reply With Quote
Old 06-24-2007   #94
J()e
J()e's Avatar
Last Online: 06-13-2011
ok,this will teach you how to control live camera in the world
1-enter www.google.com
2-type:inurl:viewerframe?mode= and press search
3-select one option
4-start controling anycamera u want
u can also try:inurl:view/view.shtml
liveapplet
The Following User Says Thank You to J()e For This Useful Post:
MARX  (06-17-2008)
Old 06-24-2007   #95
J()e
J()e's Avatar
this is a trick tht lets u restore ur bandwidth
File Type: wmv Restoring Bandwidth [from www.metacafe.com].wmv (918.9 KB, 21 views)
Old 07-22-2007   #96
Dr.Scoo
Dr.Scoo's Avatar
Last Online: 03-17-2012
Post Re: Tips n tricks!
For firefox user, this trick let u search the internet easily.
this trick let u do a search by typing in the address bar where and what u want to search.
1:Go to the search engine's webpage (e.g:www.images.google.com)
2:go to the seach bar in the site and right click and choose "add a keyword for this search"
3:in the dialog that appear type the name(e.g:google images),
and the keyword(e.g: im)
4:to use it type in the address bar :
im and what u want to search for (e.g:im area 51 )
p.s: to search google type in the address bar with no keywords what u want to search for (e.g:area 51)--> it's a web search
Dr.Scoo is offline   Reply With Quote
The Following User Says Thank You to Dr.Scoo For This Useful Post:
Kingroudy (07-22-2007)
Old 07-30-2007   #97
thugilex
thugilex's Avatar
Last Online: 02-12-2008
hahaha funny but still old , try that , open notepad and type in it : this app can break and save it and exit . then re open it and see
thugilex is offline   Reply With Quote
The Following User Says Thank You to thugilex For This Useful Post:
SysTaMatIcS (07-30-2007)
Old 08-04-2007   #98
might3d
might3d's Avatar
Last Online: 12-29-2008
for best performance in the PC :
1) right click on "my computer"
2)properties
3)advanced
4)Performance : click on Settings
5)Visuel effects ( first tab) choose : adjust for best performance
6)Advanced ( middle tab ) : choose Programs for both Processor Scheduling and Memory Usage
7) Virutal memory => change => only choose the drive C for Virtual Memory
and make it custom size :
initial = 1.5 x (size of your RAM )
Maximum = 2 x ( size of your RAM )
never let the windows manage the size .
enter OK for all , the system needs to restart , and enjoy the new speed
We Will Never Stop Learning !
might3d is offline   Reply With Quote
The Following User Says Thank You to might3d For This Useful Post:
abousoun (08-04-2007)
Old 08-08-2007   #99
thugilex
thugilex's Avatar
if u open run and type . <---- the point then press enter
or .. <--- 2 points and enter
or 3 points and enter
The Following 3 Users Say Thank You to thugilex For This Useful Post:
J()e (08-08-2007), Kingroudy (08-08-2007), SysTaMatIcS (08-08-2007)
Old 08-08-2007   #100
Dr.Scoo
Dr.Scoo's Avatar
to search for music using google intitle:index.of ...................
and to simplify this trick
in firefox create a new bookmark
copy this location (http://www.google.com/search?hl=en&q=intitle:index.of -asp -htm -html -php +mp3 "%s")
type a keyword u want it "better to be small"
type this keyword in the address bar followed by ur search terms
The Following 3 Users Say Thank You to Dr.Scoo For This Useful Post:
Justin (08-27-2007), KeXasthur (08-09-2007), Kingroudy (08-08-2007)
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
