E-Learning Center E-Learning tutorials and competitions.
Old 10-01-2008   #111
Last Online: 02-09-2020
Default Re: Tips n tricks!
it only works on IE , not on firefox.
Old 10-01-2008   #112
nope it worked on mozilla and ie for me.
try it again while opening a page (not a blank page )
javascript:function Shw(n) {if (self.moveBy) {for (i = 35; i > 0; i--) {for (j = n; j > 0; j--) {self.moveBy(1,i) ;self.moveBy(i,0);self.moveBy(0,-i);self.moveBy(-i,0); } } }} Shw(6)
Old 11-05-2008   #113
A very useful trick to lock a FOLDER. This trick has only been tested in Windows XP.
Suppose you want to lock the folder "test" in d: which has the path D:\test. In the same drive create a text file and type
ren test test.{21EC2020-3AEA-1069-A2DD-08002B30309D}
Now save this text file as lock.bat
create another text file and type in it
ren test.{21EC2020-3AEA-1069-A2DD-08002B30309D} test
Now save this text file as key.bat
Now you can see 2 batch files lock and key.Press lock and the folder test will change to control panel and you cannot view its contents.Press key and you will get back your original folder.
jak (01-17-2009)
Old 11-05-2008   #114
Google
Google's Avatar
Last Online: 05-30-2013
Well, let's explain things more here...
lock.bat is renaming the folder "test" and giving it a CLSID extension, so the folder now is referring to another object...
key.bat is restoring the folder "test" to the its original state by removing the CLSID extension, so the folder will be accessible again...
What is a CLSID?
A Class ID (CLSID) is a 128 bit (large) number that represents a unique id for a software application or application component. Typically they are displayed like this "{AE7AB96B-FF5E-4dce-801E-14DF2C4CD681}".
You can think of a CLSID as a "social security number" for a piece of software, or a software component.
What are they used for?
CLSIDs are used by Windows to identify software components without having to know their "name". They can also be used by software applications to identify a computer, file or other item.
Where do they come from?
Microsoft provides a utility (program) called GUIDGEN.EXE that generates these numbers. They are generated by using the current time, network adapter address (if present) and other items in your computer so that no two numbers will ever be the same.
So we can use the CLSID of another object, not just control panel...
Google is offline   Reply With Quote
The Following 2 Users Say Thank You to Google For This Useful Post:
Neoxter (11-05-2008), Sheriff Ice (11-06-2008)
Old 11-25-2008   #115
Last Online: 08-01-2019
In case you are heaving problems with the new gmail, then i suggest you try to reset the user agent to its default value.
i discovered that yesterday after lots of guessing.
wish i helped someone.
Old 01-11-2009   #116
how to change your IP from CMD
assume the connection name (that you find in the control panel) is local area connection and you want to set a static IP, type this in CMD
Code:
netsh interface ip set address "Local Area Connection" static 192.168.0.10 255.255.255.0 192.168.0.1 1
to set a dynamic address:
Code:
netsh interface ip set address "Local Area Connection" dhcp
also you can make batch files. lol this pwns!!
Old 01-12-2009   #117
Google
Google's Avatar
Code:
Code:
Yeah yeah... This is what's called "Windows Terminal", where no GUI!
Old 01-12-2009   #118
what the hell are u people talking about .
Old 01-17-2009   #119
MORPHEUSP
MORPHEUSP's Avatar
Last Online: 02-05-2012
looooooooooooooooooooooolll i know it;s off topic butcouldn;t help expressing this lol.. looks like systa entered the wrong forum
systa heda el mature forum in beta
MORPHEUSP is offline   Reply With Quote
The Following User Says Thank You to MORPHEUSP For This Useful Post:
SysTaMatIcS (01-17-2009)
Old 01-23-2009   #120
Kevin
Kevin's Avatar
Last Online: 02-10-2009
Computer Acronyms.
ADSL - Asymmetric Digital Subscriber Line
AGP - Accelerated Graphics Port
ALI - Acer Labs, Incorporated
ALU - Arithmetic Logic Unit
AMD - Advanced Micro Devices
APC - American Power Conversion
ASCII - American Standard Code for Information Interchange
ASIC - Application Specific Integrated Circuit
ASPI - Advanced SCSI Programming Interface
AT - Advanced Technology
ATI - ATI Technologies Inc.
ATX - Advanced Technology Extended
--- B ---
BFG - BFG Technologies
BIOS - Basic Input Output System
BNC - Barrel Nut Connector
--- C ---
CAS - Column Address Signal
CD - Compact Disk
CDR - Compact Disk Recorder
CDRW - Compact Disk Re-Writer
CD-ROM - Compact Disk - Read Only Memory
CFM - Cubic Feet per Minute (ft�/min)
CMOS - Complementary Metal Oxide Semiconductor
CPU - Central Processing Unit
CTX - CTX Technology Corporation (Commited to Excellence)
--- D ---
DDR - Double Data Rate
DDR-SDRAM - Double Data Rate - Synchronous Dynamic Random Access Memory
DFI - DFI Inc. (Design for Innovation)
DIMM - Dual Inline Memory Module
DRAM - Dynamic Random Access Memory
DPI - Dots Per Inch
DSL - See ASDL
DVD - Digital Versatile Disc
DVD-RAM - Digital Versatile Disk - Random Access Memory
--- E ---
ECC - Error Correction Code
ECS - Elitegroup Computer Systems
EDO - Extended Data Out
EEPROM - Electrically Erasable Programmable Read-Only Memory
EPROM - Erasable Programmable Read-Only Memory
EVGA - EVGA Corporation
--- F ---
FC-PGA - Flip Chip Pin Grid Array
FDC - Floppy Disk Controller
FDD - Floppy Disk Drive
FPS - Frame Per Second
FPU - Floating Point Unit
FSAA - Full Screen Anti-Aliasing
FS - For Sale
FSB - Front Side Bus
--- G ---
GB - Gigabytes
GBps - Gigabytes per second or Gigabits per second
GDI - Graphical Device Interface
GHz - GigaHertz
--- H ---
HDD - Hard Disk Drive
HIS - Hightech Information System Limited
HP - Hewlett-Packard Development Company
HSF - Heatsink-Fan
--- I ---
IBM - International Business Machines Corporation
IC - Integrated Circuit
IDE - Integrated Drive Electronics
IFS- Item for Sale
IRQ - Interrupt Request
ISA - Industry Standard Architecture
ISO - International Standards Organization
--- J ---
JBL - JBL (Jame B. Lansing) Speakers
JVC - JVC Company of America
- K ---
Kbps - Kilobits Per Second
KBps - KiloBytes per second
--- L ---
LG - LG Electronics
LAN - Local Are Network
LCD - Liquid Crystal Display
LDT - Lightning Data Transport
LED - Light Emitting Diode
--- M ---
MAC - Media Access Control
MB � MotherBoard or Megabyte
MBps - Megabytes Per Second
Mbps - Megabits Per Second or Megabits Per Second
MHz - MegaHertz
MIPS - Million Instructions Per Second
MMX - Multi-Media Extensions
MSI - Micro Star International
--- N ---
NAS - Network Attached Storage
NAT - Network Address Translation
NEC - NEC Corporation
NIC - Network Interface Card
--- O ---
OC - Overclock (Over Clock)
OCZ - OCZ Technology
OEM - Original Equipment Manufacturer
--- P ---
PC - Personal Computer
PCB - Printed Circuit Board
PCI - Peripheral Component Interconnect
PDA - Personal Digital Assistant
PCMCIA - Peripheral Component Microchannel Interconnect Architecture
PGA - Professional Graphics Array
PLD - Programmable Logic Device
PM - Private Message / Private Messaging
PnP - Plug 'n Play
PNY - PNY Technology
POST - Power On Self Test
PPPoA - Point-to-Point Protocol over ATM
PPPoE - Point-to-Point Protocol over Ethernet
PQI - PQI Corporation
PSU - Power Supply Unit
--- R ---
RAID - Redundant Array of Inexpensive Disks
RAM - Random Access Memory
RAMDAC - Random Access Memory Digital Analog Convertor
RDRAM - Rambus Dynamic Random Access Memory
ROM - Read Only Memory
RPM - Revolutions Per Minute
--- S ---
SASID - Self-scanned Amorphous Silicon Integrated Display
SCA - SCSI Configured Automatically
SCSI - Small Computer System Interface
SDRAM - Synchronous Dynamic Random Access Memory
SECC - Single Edge Contact Connector
SODIMM - Small Outline Dual Inline Memory Module
SPARC - Scalable Processor ArChitecture
SOHO - Small Office Home Office
SRAM - Static Random Access Memory
SSE - Streaming SIMD Extensions
SVGA - Super Video Graphics Array
S/PDIF - Sony/Philips Digital Interface
--- T ---
TB - Terabytes
TBps - Terabytes per second
Tbps - Terabits per second
TDK - TDK Electronics
TEC - Thermoelectric Cooler
TPC - TipidPC
TWAIN - Technology Without An Important Name
--- U ---
UART - Universal Asynchronous Receiver/Transmitter
USB - Universal Serial Bus
UTP - Unshieled Twisted Pair
--- V ---
VCD - Video CD
VPN - Virtual Private Network
--- W ---
WAN - Wide Area Network
WTB - Want to Buy
WYSIWYG - What You See Is What You Get
--- X ---
XGA - Extended Graphics Array
XFX - XFX Graphics, a Division of Pine
XMS - Extended Memory Specification
XT - Extended Technology
sanity calms but madness is more interesting.
Kevin is offline   Reply With Quote
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
