E-Learning Center E-Learning tutorials and competitions.
Old 01-31-2009   #121
Default Re: Tips n tricks!
Trick: Hide Folders
start>run>cmd
enter the Drive or location where your folder lies
for Eg: if your folder is in the D Drive
Enter "D:" without quotations,hit enter.
Then type this:
attrib foldername +r +a +s +h
hit enter,now its hidden.
To Unhide :
do the same process the only change is :
attrib foldername -r -a -s -h
Old 02-17-2009   #122
Google
Google's Avatar
Last Online: 05-30-2013
Originally Posted by Neoxter View Post
Trick: Hide Folders
start>run>cmd
Then type this:
To Unhide :
No need to type all this!
r => read only
a => archive
s => system
h => hidden
Use only s and h...
+s makes a file a system file
+h makes a file a hidden file
- is for the inverse...
Google is offline   Reply With Quote
Old 08-28-2009   #123
how can i increase the size of the bookmarks' toolbar in Mozilla FF ?
Old 08-28-2009   #124
Google
Google's Avatar
I think of two options:
-Edit Mozilla Firefox core files.
-Create an extension (add-on) and overlay the size of the toolbar.
I don't know if there are other options...
I'll tell you how to do this once I get internet to work @ home.
Old 08-29-2009   #125
I Googled and found what you've said, but i'm more into simpler things
Old 09-04-2009   #126
Google
Google's Avatar
Making things as simple as possible, I have chosen yet another method to edit the bookmarks toolbar of Mozilla Firefox. I overlayed the bookmarks toolbar using userChrome.css which is available/need_to_be_placed in "chrome" directory of Mozilla Firefox user configuration files located on your computer. + I added the auto-hide_bookmark_toolbar feature (other than the multi-row_bookmark feature).
Save the following file and copy it to the path written.
Enjoy.
The Following User Says Thank You to Google For This Useful Post:
Neoxter (09-04-2009)
Old 09-04-2009   #127
Thanks! i put the file in the "chrome" folder but now what ? how i'm supposed to get a bigger toolbar ?
Old 09-15-2009   #128
i figured how to work it out, lol i didnt read the file before.
anyway how can i disable the auto-hide feature?
Old 09-16-2009   #129
Google
Google's Avatar
You still didn't read the file properly.
I wrote there:
Note: Use the comment tags to disable any feature.
So comment the auto-hide code section like this (you can also delete it instead) :
Code:
/* Auto-hide bookmarks toolbar
#PersonalToolbar {visibility: collapse !important;}
#navigator-toolbox:hover > #PersonalToolbar {visibility: visible !important;} */
Post please a screen_shot of the result for others to see.
Old 09-16-2009   #130
yeah i read that and i used the search ctrl + F to find "hide" and i got no match, it turned out that i have to put search up instead of down..
here it is:
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
