E-Learning Center E-Learning tutorials and competitions.
Old 12-28-2006   #61
Dr.Scoo
Dr.Scoo's Avatar
Last Online: 03-17-2012
Default Re: Tips n tricks!
a trick i will add in addition of brother ruudzz :
shift+no=no to all
Dr.Scoo is offline   Reply With Quote
Old 12-30-2006   #62
ali_masri
ali_masri's Avatar
Last Online: 02-24-2008
what does Winkey + M & Winkey + D Means???
please reply
ali_masri is offline   Reply With Quote
Old 12-30-2006   #63
god
god's Avatar
Last Online: 02-14-2010
welcome ali_masri to the forum, winkey = the little key that's to the right of Right-Alt , it has the windows Logo in it, press it simultaneously with M or D and it will minimise/dropdown your opened windows.. try it
--Capitalisation is the only difference between "I helped my uncle Jack off a horse" and "I helped my uncle jack off a horse" !!
http://img482.imageshack.us/img482/4889/hell7ta.jpg
god is offline   Reply With Quote
Old 01-04-2007   #64
Last Online: 08-01-2019
Renaming Desktop Icons
You can easily rename various Desktop (System Icons).
Click Start, Run and enter REGEDIT. Navigate to the following Registry brach:
HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Explorer\CLSID
The Desktop Icons are located in the sub keys as follows:
My Network Places: {208D2C60-3AEA-1069-A2D7-08002B30309D}
My Computer: {20D04FE0-3AEA-1069-A2D8-08002B30309D}
My Documents: {450D8FBA-AD25-11D0-98A8-0800361B1103}
Recycle Bin:{645FF040-5081-101B-9F08-00AA002F954E}
Default IE Icon: {871C5380-42A0-1069-A2EA-08002B30309D}
Double click the Default value in the above keys and enter the text you desire. Right click on the Desktop and select Refresh to see the changes.
To undo the changes, just right click on the Default value and select Delete. Refresh the Desktop to see that things are back to normal.
Old 01-04-2007   #65
i don't know if u ll find thi simportant but instead of typing the www. and the .com when u want to open a website just write for example vcoderz and press ctr + enter
Old 01-04-2007   #66
Banbino
Banbino's Avatar
Last Online: 04-03-2008
When You press winkey + M bitsaker kill shi fet7o w bass lama tirja3 tikbissa mabiseer walla shi ...
Bass bass lama tikboos winkey + D bisaker kil shi w izza rji3it kabastta byirja3o byifta7oo !!
m3alim sa7?:P
Banbino
Banbino is offline   Reply With Quote
Old 01-10-2007   #67
Sony
Sony's Avatar
Last Online: 07-12-2012
nice tricks i feel like master of the P.C.
Sony is offline   Reply With Quote
Old 01-13-2007   #68
abousoun
abousoun's Avatar
Last Online: 04-16-2011
I already made a thread for this several months ago ... but i think it's best placed in this thread ... that way we'll have a bigger collection of tips
How to add ur picture & personel informations to system properties on WinXP:
follow the following steps:
1- You need to create 2 files (oeminfo.ini and oemlogo.bmp)
2- put the following infomations in the file named (oeminfo.ini)
[general]
Manufacturer=your name or your store name
[Support Information]
Line1=For Technical Support contact:
Line2=
Line3=Store Name.
Line4=555-555-5555
Line5=address
Line6=
Line7=http://www.vcoderz.com
3- have your .bmp file (ur picture) named oemlogo.bmp and make it no larger than 100x70 (using paint or whatever else)
4- Put both of the files (oeminfo.ini and oemlogo.bmp) in the /windows/system32 dir.
P.S: you can write beside Manufacturer and Line1,2,3...etc whatever you like or just leave them blanck ... and u can have as many lines as u like inside the (oeminfo.ini) file ...
Remember the file is called (oeminfo.ini) and not (oeminfo.txt) or (oeminfo.ini.txt) ...
[you can do this by double clicking on "My Computer" and then in the "Tools" Menu choose "Folder Options" and then go to the "View" Tab and then search for the "Hide extensions for known file types" and remove the correct sign beside it ...
later on you create on your desktop a new "text document" and name it (oeminfo.ini) without the brackets of course ]
to view your work right click on My computer and choose properties and you'll see the difference ...
I put an example pic below on what you'll expect when u finish this
Thank You ...
Jess' Signature
Old 01-26-2007   #69
moetart
moetart's Avatar
Last Online: 11-19-2010
Lightbulb Re: Tips n tricks!
hey guyz cool thread
in schools and some unis there are some restrictions so u dont have administrative privileges so u can go to run/cmd/control userpasswords2
and then control administrative passwords and change'em create new users and add em to administrators
IndpMOE
moetart is offline   Reply With Quote
Old 01-26-2007   #70
KeXasthur
KeXasthur's Avatar
Last Online: 12-17-2012
and also instead of typing www. ???????? .org
you can write the name of the site and then
ctrl + shift + Enter
or www. ?????? .net
write the name of the site then
you press shift + enter
even though I dont think they are very useful but still, nice info ... makes Sony feel more like the MAster of P.C
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
