Old 07-30-2007   #11
Default Re: my problem , troubles , errors etc. thread :D
well i dont know wat to say , theres isnt any advanced tab , i even went to the documents and settings and done the same on my documents the same...
Old 07-30-2007   #12
Dr.Scoo
Dr.Scoo's Avatar
Last Online: 03-17-2012
there's no advanced tab
go in here and check encrypt ....
Dr.Scoo is offline   Reply With Quote
Old 07-30-2007   #13
FriendOfZeus
FriendOfZeus's Avatar
Last Online: 08-22-2008
maybe he has windows home edition
FriendOfZeus is offline   Reply With Quote
Old 07-30-2007   #14
no i have the proffesional sp 2 , theres no advanced button!
Old 07-30-2007   #15
McNaOH
McNaOH's Avatar
Last Online: 06-19-2009
jarrib haydi :P right click on folder, open properties, go to the tab called Sharing, and check Make This Folder Private.
Let's go mad !!
McNaOH is offline   Reply With Quote
Old 07-30-2007   #16
Dr.Scoo
Dr.Scoo's Avatar
no way man something is going wrong man.
no way u should have the advanced button it's in the general tab.
well try ,in the sharing tab, checking "make this folder private"
Old 09-02-2007   #17
i installed arabic languauge on my pc!!! but i cant type arabic!!
Old 09-02-2007   #18
lebanese_a
lebanese_a's Avatar
How do you install arabic on your PC, I also can't/don't know how to type arabic
Old 09-02-2007   #19
if u have the windows xp cd , go to control panel >> date , time , language etc... >>regional and languauge options >> languages tab >> tick install files for complex .....
The Following User Says Thank You to SysTaMatIcS For This Useful Post:
lebanese_a (09-03-2007)
Old 09-02-2007   #20
u will have then to install arabic from the advanced tab systamatics u missed that!!
The Following User Says Thank You to Kingroudy For This Useful Post:
errors, problem, thread, troubles
