Old 09-03-2007   #21
Default Re: my problem , troubles , errors etc. thread :D
and wat to do next???
Old 09-03-2007   #22
click ok with the windows CD in ur drive:"D then, left alt + shift to switch to arabic, or simply, right click on the taskbar, toolbars, language bar. select arabic from there:"D
Old 09-04-2007   #23
Sheriff Ice
info@sync.com.lb
Sheriff Ice's Avatar
Last Online: 11-29-2020
man i think its enough to install the east asia and middle east language package to install arabic go to control panel reginal and language options than go to the language bar and choose arabic its very simply procedure
Old 09-04-2007   #24
ddnt work at all , somethings wrong! probably cuz of the multi wondows i have , could it be from it??
Old 09-04-2007   #25
control panel >>regional and languauge options >> languages tab >> tick install files for complex .
u will have then to install arabic from the advanced tab.
i can't make it any clearer
The Following User Says Thank You to Kingroudy For This Useful Post:
SysTaMatIcS (09-04-2007)
Old 09-04-2007   #26
IT WORKED by by the advanced tab king roudy told me abt
Old 09-30-2007   #27
In order to use Windows Live Hotmail, please set your browser to enable cookies. The following instructions will only allow cookies for Windows Live websites. Otherwise, you will have the same level of privacy protection as before.<br/><p>For Internet Explorer 6 and higher:</p><li>Click Options...from the Tools menu.</li><li>Click the Privacy tab, and then click the Sites button.</li><li>Add Live Search under the Address field, and then click the Allow button.</li><li>Click OK to confirm, and then click OK again to leave Internet Options.</li><li>Now you should be able to <link>sign in to Windows Live Hotmail.</li><br/><p>For Mozilla Firefox 2.0 and higher:</p><li>Click Internet Options from the Tools menu.</li><li>Click the Privacy tab, and then click the Exceptions...button.</li><li>Add Live Search under the Address field, and then click the Allow button.</li><li>Click Close to confirm, and then click OK again to leave Options.</li><li>Now you should be able to sign in to Windows Live Hotmail.</li>
i cant acess hotmail , nd this is wat im gettin
Old 09-30-2007   #28
Dr.Scoo
Dr.Scoo's Avatar
Last Online: 03-17-2012
do wat u r asked to do ,, yi3ni enable cookies
Dr.Scoo is offline   Reply With Quote
Old 09-30-2007   #29
i did that and added live.com to the allowed sites
Old 10-06-2007   #30
in facebook , watever page i try to inter its redirectin me to this site
http://ad.accelerator-media.com/?ad_...8j%2FfLnpqg%3D
errors, problem, thread, troubles
