E-Learning Center « E-Learning tutorials and competitions. »
Old 08-27-2007   #101
might3d
might3d's Avatar
Last Online: 12-29-2008
Default Re: Tips n tricks!
the ordinary formatting needs about 1 hour ro delete/install the windows
but the expert needs to format the hardisk in deep way , that format needs about 5 or 7 hours ( depending on the number of the bit in the hard drive )
norton Ghost , simply may format your hard drive in just 5 or 10 min ( uncompressed imaging ) and about 1 hour ( compressed imaging )
Norton ghost has one single problem , it MIGHT not leave the coded program to work properly after the ghsoting
but when you want a clean windows , the solution still in : the expert formatting ( 5 hours )
We Will Never Stop Learning !
might3d is offline   Reply With Quote
The Following User Says Thank You to might3d For This Useful Post:
Justin (08-27-2007)
Old 09-23-2007   #102
chadchoud
chadchoud's Avatar
Last Online: 04-19-2008
Default Hide a folder
On the desktop for example, create a folder, name it (alt+0160)
Then change its icon to a hidden (transparent) one :P
chadchoud is offline   Reply With Quote
Old 10-13-2007   #103
Dr.Scoo
Dr.Scoo's Avatar
Last Online: 03-17-2012
for DFX users,
its better to choose a preset than adjusting manually the DFX.
Dr.Scoo is offline   Reply With Quote
Old 12-01-2007   #104
Dr.Scoo
Dr.Scoo's Avatar
For Mozilla Firefox userz. DONT Download Firefox every time.
just check for update.(Help-> CHECK FOR UPDATE)
Old 03-08-2008   #105
LebEyeC
LebEyeC's Avatar
Last Online: 03-13-2008
First of all hello everybody, this is my first post. i don't know if this trick is posted before because i didn't read all the tricks.
This is one of my favourite tweaks as it makes a huge difference to how fast your machine will 'feel'. What this tweak does is remove the slight delay between clicking on a menu and XP displaying the menu.
MAKE YOUR MENUS LOAD FASTER
Go to Start then Run
Type 'Regedit' then click 'Ok'
Find "HKEY_CURRENT_USER\Control Panel\Desktop\"
Select "MenuShowDelay"
Right click and select "Modify'
Reduce the number to around "100"
This is the delay time before a menu is opened. You can set it to "0" but it can make windows really hard to use as menus will open if you just look at them - well move your mouse over them anyway. I tend to go for anywhere between 50-150 depending on my mood.
Nice forum, keep up the good work.
LebEyeC
LebEyeC is offline   Reply With Quote
Old 03-20-2008   #106
Dr.Scoo
Dr.Scoo's Avatar
open about:config in Firefox, search for this "browser.search.openintab".
put it to true.
now when u want to search using the google bar in the top no need to open a new tab. Firefox will do it.
The Following User Says Thank You to Dr.Scoo For This Useful Post:
TAREK® (03-20-2008)
Old 10-01-2008   #107
Shake Dat Browsa'
Paste this code in your Mozilla Firefox browser and see what happens
javascript:function Shw(n) {if (self.moveBy) {for (i = 35; i > 0; i--) {for (j = n; j > 0; j--) {self.moveBy(1,i);self.moveBy(i,0);self.moveBy(0,-i);self.moveBy(-i,0); } } }} Shw(6)
abousoun (10-01-2008)
Old 10-01-2008   #108
Windows XP Cheatz
Solitaire: Instant Win
  1. Press Alt + Shift + 2 to instantly win
Solitaire: Draw only 1 card (instead of 3)
  1. Hold down Ctrl + Alt + Shift then click on unopen cards to draw.
FreeCell: Instant Win
  1. Hold down Ctrl + Shift + F10 while playing, then click Abort.
  2. Now move one card.
FreeCell: Hidden Game Modes
  1. Go to "Game" menu choose "Select Game"
  2. Here you can choose from game mode 1 to 1,000,000. But -1 and -2 will also work (hidden modes)
Hearts: Show All Card
  1. Warning! this requires a modification on your registry. Be sure you follow the steps carefully. Damage your registry might damage your Windows.
  2. Open the "Registry Editor" by: "Start" >> "Run" then type "regedit" and press Enter
  3. Expand to HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Applets\Hearts
  4. Right-click on the right panel and create a new String value with the name "ZB"
  5. Double-click to open this key "ZB" to edit its value. Then enter "42" and close the Registry Editor.
  6. Start Hearts and Press Ctrl + Alt + Shift + F12 to show all the cards
Minesweeper: Stop The Timer
  1. When you start to play a new game, the timer is ticking...
  2. Press Windows Key + D to show desktop.
  3. Now come back to the game by selecting it from the taskbar. The timer is stopped.
Pinball
  1. Unlimited Balls: Type bmax at a new game to get unlimited balls (no notification).
  2. Extra Balls: Type 1max at a new game to get extra balls.
  3. Gravity Well: Type gmax at a new game to activate Gravity Well.
  4. Promotion: Type rmax at a new game or while playing to get instant promotion and raising rank.
  5. Extra points with partial shots: Partially shot the ball just to pass the yellow light bars. There are 6 bars. With the first bar, you'll get 15,000 points, 2nd: 30,000,...
  6. Extra points with partial shots: Partially shot the ball just to pass the yellow light bars. There are 6 bars. With the first bar, you'll get 15,000 points, 2nd: 30,000,...
  7. Test Mode: Type hidden test with a new ball or new game. Now you can use your mouse to drag and move the ball where you want.
Old 10-01-2008   #109
Last Online: 08-27-2020
Originally Posted by Neoxter View Post
Shake Dat Browsa'
Nothing Happened Over Here The Browser Just Restored Down.
Old 10-01-2008   #110
abousoun
abousoun's Avatar
Last Online: 04-16-2011
It shaked hard for me , then get minimized
P.S: I tried it on Firefox browser as the post says
Thank You ...
Jess' Signature
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
