Computers & Information Technologies Everything related to computers and internet.
Old 11-25-2009   #281
7alewi
7alewi's Avatar
Last Online: 09-03-2014
Originally Posted by Justin View Post
Guyz, does someone have any software in which I can get access to copy original DVDs? I have so many live concerts and performances and I cannot copy them due to protection. so I need a software unlock or something so i can share the DVDs with my friends
thx in advance
And I need a software or a way to copyright the songs
Thanks
Old 11-25-2009   #282
Last Online: 08-01-2019
7780 is the factory settings.
7370 is the Soft Reset.
the three fingers maneuver is the Hard Reset.
The Following User Says Thank You to Kingroudy For This Useful Post:
Justin (11-25-2009)
Old 11-25-2009   #283
Justin, there you go, you should try www.slysoft.com/en/anydvd.html
Justin (11-25-2009)
Old 11-25-2009   #284
MORPHEUSP
MORPHEUSP's Avatar
Last Online: 02-05-2012
Justin you have the anydvd but to use it you must know some stuff
Anydvd,
once installed and the original stuff is inside the rom, open the program go to css and substitute the keys (currently i don't have it on my pc i would've shown some screenshots)
but there is an easier solution, search for DVDFAB Platinum and dont install anydvd it will break any protection automaticly/split/preserve menues/remove extra sounds and burn
Download DVD FAB
MORPHEUSP is offline   Reply With Quote
The Following User Says Thank You to MORPHEUSP For This Useful Post:
Justin (11-25-2009)
Old 11-26-2009   #285
Last Online: 02-09-2020
Originally Posted by Tawa View Post
Check The Forth Post. "w 7aj tetfalsaf " Don't forget to check the rank of the users who posted it.
@ Systa, I forgot the mention the 3 Buttons Hard Reset:
- Turn of your phone.
- Press and Hold down the following 3 buttons: Green Call Key + '*' Key + Number 3 Key.
- While holding the buttons, turn the mobile on, and keep holding the buttons until the mobile phone restarts and prompts you to enter details.
i did that too , guess ill firmware update , btw why the hell is the os so complicated!! da3 deeni! nokia was alway known for the simplicity of its os , now they blew it and btw does it have a reminder? like the one in 6300 you set an alarm about somethin and when it sets it reminds u of wat u need to do ( a task , studying etc...)
Old 11-26-2009   #286
How can i know if the windows 7 dvd that i got is the final build not rtm or rc?
Old 11-26-2009   #287
Last Online: 08-27-2020
Nokia N95 OS is complicated? you have got to be kidding me.
The reminder thing can be set in the calender, or in the To-Do List.
It's easy when you have the Active Standby activated {I know you're gonna ask where is that, so I'll guide you, Settings ~> General ~> Personalisation ~> Standby Mode ~> set Active Standby to On}
Old 11-26-2009   #288
yeh its complicated compared to the 6*** and the other numbers models , where is the to do list located? i deactivated the stand by mode , hate it.
Old 11-27-2009   #289
w bet2elli not complicated? , how the hell can i choose a certain file to put as a ringtone??i got to the file manager and choose the folder and the ringtone , and there i cant set it as a ringtone , i go to profiles then choose the ringtone i cant surf like in the file manager , so ill have to go in and search in my 900 files for the ringtone -__- . isnt there anyway to do this faster?
btw how do i save the bluetooth files tht i received?
Old 11-29-2009   #290
and how can i move files between folders?? all i can do is send to mass memory or phone memory .
detective, driver, needed, program, requests, softwares, thread
J O K E S Thread ;) badboy_10452 Funny Stuff 144 11-03-2006 10:10 PM
a pic in a thread! Malak Announcements & Feedbacks 3 10-03-2006 08:13 PM
softwares and aplications cash88 Computers & Information Technologies 7 09-13-2006 05:35 PM
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
